fuel pump replace 2000 115hp
Is there a replacement fuel pump for 2000 115 johnson, I want to take off the vro and just put a regular premix pump in.vro number is 438400. Thanks
Faztbullet
Re: fuel pump replace 2000 115hp
If thr VRO is not bad just bypass the oil line and make it a premix pump...
As far I as I can tell it is bad, have to keep pumping bulb to keep running when it was to stall out at idle, no air leaks tested on external tank same issue. Just wanted to skip the vro and use a normal pump if possible just can't figure out which one.
Faztbullet
You should have the 60 degree engine and its better to go ahead and buy replacement VRO. If you want a aftermarket kit (pain in butt) to install and modify fuel bracket google 8402-60 fuel pump.
boobie
Robert, where did you ever get that site from ?? LOL. By the way, how did your motor turn out ??
Roberthill
I got that site from you .Parts are here, haven't installed yet .
boobie
Let us know the outcome and take your time doing it.
Roberthill
Material on motor piston was soft and came loose from piston .Put new kit in ,everything worked good . Good thing I took pictures when I removed it from motor ,lots of hoses .Thanks again for all the help .
Robert
