Re: Fuel pump question
Removing the screens will not give more power: Removing them will ensure better fuel delivery to the carbs because of less restriction.
Now, on to your 146 degree. I chose 146 degrees because I did not have a calculator in front of me and the crankpins on the 5 cylinder are 72 degrees apart (I thought 73). Thus the most difference available is 144 degrees.
Now, operation of that type fuel pump. It is the Chrysler "B" type pump. It has two stages: The first stage supplied with alternate pressure and vacuum through a small port or hole in the body of the bypass cover, under the large diameter portion of the diaphragm. The second stage (with the small diameter portion of the diaphragm) is supplied again with alternate pressure and vacuum pulses through the third nipple through the hose, from a different cylinder crankcase.
In the ideal world of the two or four cylinder engine, these pulses are 180 degrees apart because the crankpins are 180 degrees apart. Thus: While stage one is under pressure and pushing fuel out to stage two through the center button valve, stage two is under vacuum and trying to suck in the fuel.
In the less than ideal world of the three cylinder engine, the pulses are about 120 degrees apart and in the five cylinder engine, ideally they would be 144 degrees apart.
In your photo, pump one is feeding fuel to pump two which will help increase the delivery amount. This is as it should be. Both pumps derive their pressure and vacuum pulses from different cylinders, again, as they should.
The important thing is that the third nipple must be connected to a different cylinder than the pump body as your photo shows it is.
I have not worked on the fuel system of the 5 cylinder engine and did not study the pumps. Since the crankpins are only 72 degrees apart, the plumbing of the hoses will be different than on the 2, 3, or 4 cylinder engines.
