janpetemar
- Jul 18, 2009
- 24
My Chevy engine is an in-line 4 cyl with dual RBG carbs. The boat came with an alternative electric fuel pump mounted on the inboard transom with a fuel selector for running from main forward tank or reserve 6 gallon tank in rear. It also includes a fuel flow regulator mounted after the water seperator. The original or oem fuel pump mounted on the port side, between the oil filter and the starter appears to be a single diaphram mechanically driven pump.
Question is, when I changed the oil, there was fuel found, that I can assume is coming from a bad pump. Would I be better off in replacing the original pump with a dual-diaphram pump, installing fuel filters at the carbs, which there are none currently, and taking out the alternative system, and being able to provide proper fuel pressure required? I figure I should solve this problem prior to rebuilding the carbs, which sat too long between use.
