Re: Fuel Pump Pressure ?'s
Have yet to see an outboard that NEEDED fuel pressure regulation. <br /><br />Spitting from carbs is somewhat normal to a small extent. Also on 2 stroke motors a small amount of unburned gas and oil from exhuast at idle speed(s) is somewhat normal.<br /><br />If the carbs are dumping raw fuel and dribbling all over the place it's time to remove them and clean or replace the needle/seats.<br /><br />If you are experiencing a lot of sprayback out of one carb it might indicate bad reeds. This will also be evident as a loss of power/ poor idle/ stalling because that cylinder isn't running well, if at all.
