jakers4777
Thread starter- Joined
- Jan 11, 2003
- 12
I just changed over from VRO to a standard fuel pump. I saw a post here that said the standard pump won't pump enough volume of fuel to run the engine.<br /> True? The pump I installed on an 89 40hp Johnson recreation model is the same pump a 40hp commercial engine uses so why would it not be ok on mine?<br /> I took the VRO off because I was not getting enough fuel flow and figured that I was also not getting enough oil flow so better to be safe than sorry I put in a regular fuel pump.<br /> I've been mixing gas and oil for 45 years and never had a problem with an engine caused by lack of lube, the VRO might be a good idea but I just don't trust it.<br /> Anyway, is there any reason a standard fuel pump wont work on my Johnson 40?
