Re: fuel pump issues
An engine will run perfectly well with no load on it so that's why it appears to be ok in the driveway. Launch the boat and when the engine bogs, squeeze the primer bulb a few times. If the engine seems to come to life, you have a fuel delivery problem. While the fuel pump may be the culprit, you could also have some carb related problems.
