Re: Fuel pump for a '93 Johnson 200hp
If I'm not mistaken, you'll need two conventional fuel pumps. Getting the correct plumbing to operate both may be problematic without considerable modification. You could end-up blowing the motor in your attempt to get around that universially maligned VRO pump that has been very reliable since the first problematic ones came out in the mid 80s. After those, most problems have a lot more to do with water getting into the oil tank.
