Just posted this 10 min ago and my post disappeared - sorry if there are two now....
Just heard from the shop and they said there is a knocking in my engine. The upper fuel pump was bad so I assume that this is the cause because I have had no alarms. So I'm going to check the compression, but im not hopeful. They told me it would be the wrist pin or the bearing on the wrist pin.
Do I have to rebuild or can I just replace the wrist pin and bearings on the two upper cylinders? I know i'll need to pull the heads and look inside to see if there is any scoring or obvious wear. If there isn't can I just fix the bearing and pin?
And as to the heads and reinstalling them. Can I just scrape them and use perfect seal or do I need to get them finished?
thanks
Mike
thanks
Mike
