I am replacing my fuel pump diaphram due to what I observed as a loss of pressure at high rpm. I have about 3 psi at idle and it drops to zero at high rpm. I tryed running it off a protable tank and had the same results. I took the fuel pump apart. I found no tears in the diaphram. My question is, will the pressure still drop from a bad diaphram if there are no tears in it?
