fuel problems
howster
i changed my fuel filter the other day because it was dirty got about an hour running time on the motor and its dirty again it looks like little black flakes my tanks plastic can this make my engine run bad?<br /> thanks for all the help :) THE HOWSTER!!!
madecool
Re: fuel problems
For the answer is yes depending how much of those lillte black flakes are in your filter they might clog up the filter after a while and maybe get through if there a lot of them. I got a similar problem with my tank " In a big way last weekend I was at the boat ramp and the hose was stopped up not the filter this to can happen and cause your engine not to run because even though the filter is after it the line was stopped up and fule got to the filter but would not get in the engine the right way. I unclogged the connection by running a electric tie througn the hoses then pumped the primer some. But in your case i suggest getting a see through gas filter and putting it the line like mine is I got one filter in the engine and one right before it on the gas line clear one big. That way just keep a eye on the filter. Will give you a idea that will help you some.<br />But if your really worried replace the lines and the tank to be on the safer side also.
Hooty
Re: fuel problems
Are you talking about the filter in the fuel pump or somewhere else? How old is the fuel line from the tank to the fuel pump?<br /><br />Hooty
howster
Re: fuel problems
thanks guys for the reply!!!<br /> the filter is on the hose before the pump about 1 foot from primer bulb. the fuel line is only about a month old but dont have a clue on how old the fuel was being the tank is plastic i wonder if if the gas varnished but could that come though like little flakes? :confused:
