I am new to working on outboards and have a 1990 johnson 25 hp elec. start it was setting up a little over a year when I inherited it, so I put a new filter on and cleaned the gas tank, put new mix in 50:1, drained the carb bowl, sprayed carb with cleaner, and replaced the spark plugs with correct marine plugs. The motor ran for a short time then stalled out and left gas and oil in the water, I have checked the suction through the gas inlet and the float does not appear to be stuck, I ran sea foam through the gas inlet and checked to see if the fuel line was squirting fuel on start up by removing it and turning the key over and it is, the engine only runs and starts when the throttle is manually pressed down to wide open and then runs like it is starving for fuel, I placed a hose on the gas inlet where the fuel hose goes and ran sea foam through the hose while I started the engine and it ran perfectly at idle, and at all positions of throttle, i then put the fuel line back in and got nothing. I am at a stand still and need some help, thank you in advance for sharing your thoughts on my issue.
