expertoarman
- Nov 23, 2014
- 20
HELP!!!!! 1984 bf100 starts good, idles good, runs 5 min at mid throttle the dies. No fuel in float bowl, I have replaced fuel lines,bulb, filter, fuel pump, needle valve, carb is spotless.. It will idle in gear all daylong. I can feather the bulb and it will stay running, float height is at 10mm. comp is good, 95+98 tank is good and vents, does it with cover on or off no difference. Put all clear lines on to watch fuel for vapor lock lines stay full after it stalls no bubblesno problems seen. Not getting hot, new impeller and all seals. All i can think of is a sticky needle or seat. Starts up in 1-2 pulls after stalling. Any input from anybody ? I"ve done the thermostat, plugs are tan colored . THANKS any help will be greatly
