fuel problem - I think?
Aquaholictomc
I have a 1988 50 HP Yamaha on a 15 foot bowrider. I was out yesterday and had a problem with the engine. I beached it and found that when I checked it the fuel was not geting to the gas filter. I checked the gas line from the tank after the ball and that was working fine when I depressed the little ball. I figured out that the fuel pipe joint was not working correctly. I bypassed it and connected the fuel line directly to the fuel filter connection. On my way back home the engine ran perfectly for a few minutes and then bogged down to about 1500 rpm. I made it home very slowly and because of the weather couldn't check much further other than to notice when I got in I found the fuel ball was not hard and when I pumped it up the engine RPM's increased.
I just ordered a new fuel pipe joint, which I know I need but my question is, will the engine run OK without the fuel pipe joint, with it's built in check valve?
