Hello all,
I have a 50hp Force 1990 (D) outboard that has been sitting for a year an a half in my side yard. Ive refurbished the boat its attached to and did the basic maintenance on the engine, but it was left sitting unwinterized (fuel in lines and whatnot).
Im trying to get it started now, but i think im having fuel line problems. It turns over fine, and runs for a few seconds when ive sprayed carb cleaner into the carb, but not without. Ive got good fuel flow from a portable tank thru the bulb, to the point where it inputs into the fuel pump of the engine. Can anyone help me troubleshoot it past there? Is it likely that (ethanol) fuel has damaged the seals in the carb? or fuel pump?
Can i take the fuel line off the input to the carb and crank the engine to see if any fuel comes out to rule out the fuel pump?
Im pretty mechanically inclined but am ignorant of some of the working of an engine.
Any help would be greatly appreciated...
Thanks in advance,
Justin
Thanks in advance,
Justin
