john51277
- Feb 2, 2008
- 108
We were out on the local lakes and decided to idle through the Dora Canal. It is about a 20-30 min idle to get to the end. Once we got out I gave it gas and came up on plane and then it just slowed down. It will start and idle just fine. If I put it in neutral and gas it, it will increase RPM just fine. Under load it does slow down, but does not die. I checked the plugs and they were clean and had just a small amount of gas/oil on them. I did take off the fuel filter and found some junk in the intake. I will replace the filter as I am hoping this will be the fix. Anyone have any suggestions???
