sambrigman
- Jan 29, 2010
- 213
My 40 will not run right! I had carbs rebuilt, a new fuel pump, did not help. My fuel primer could be the problem? There is no fire going to it.Should it have fire when ignition is switched on? Where does wire connect? What direction should the red switch be in? This is my first experience with a fuel primer.Could this cause my problems? Would this motor run without a fuel primer? thanks, Sam
