fuel primer pump
wanna30speck
Engine seems like it is running on two cylinder at idle when 1st started. Squeeze the fuel primer and engine starts and runs great. It may act up again but once I pump it up it runs good and runs good all the time up to full throttle . Primer seems to be half empty when this happens. Can someone please advise?
Dhadley
Re: fuel primer pump
Welcome!<br /><br />Lets start at the begining. What motor do you have?
wanna30speck
Got ahead of myself. 80's 115 Seahorse powerhead with 96' 88special everything else.
fireman57
Could have a bad connection on the fuel line or might be time for carbs to be rebuilt. Get a good manual and rebuild them yourself. you will save three times the cost of the manual in labor doing it yourself. Besides, it's fun.
wanna30speck
I am changing fuel lines because where it connects to the bottom of the engine cover seems loose. The carbs were (as I was told by prev. owner) were just rebuilt a year ago. Any other things I could check.
