2003 Sea Pro 22' walk around. 105 gallon aluminum fuel tank.
Fuel primer bulb is collapsing while my brand new Suzuki 175 outboard is running.
- Replaced anti siphon valve on fuel tank
- Removed priming bulb from fuel line and visually inspected it
- No in-line fuel filter between tank/ engine
- Haven't experienced any loss of power, even cruising at 5,000 RPM. Which is weird..
I'm thinking fuel pickup line inside fuel tank is clogged? Is there a screen on the bottom of the pickup? Must be a bi** to pull that out. Barely enough access to change anti siphon valve.
Any other ideas?? Thank you!!
