fuel pressure testing-70h.p. Evinrude VRO
JoesBoats
I just did a fuel pressure test on my engine last night and I am getting about 4.5 to 5 lbs. of pressure at full throttle.I have a Clymer manual which states that you should have a reading between 3-15 p.s.i. at full throttle. Does this mean it varies as you give it more gas or any reading between this is o.k. The problem I've been dealing with is bogging down on take off and sometimes it does take off.But then a few minutes later it slowly loses power.
clanton
Re: fuel pressure testing-70h.p. Evinrude VRO
OMC manual for 1995/97 reads no less then 3 psi at 800 rpms, no specs for any other rpms.
JoesBoats
Thanks Clanton,just needed a little bit of feedback on that for peace of mind.
