Fuel plumbing on a Volvo AQ125A
ThePostMan
I'm looking to clean up the engine compartment and replace all the rubber, and I'm looking for some advice on fuel plumbing.
The previous owner has the following set-up coming out of the fuel tank pick-up: Fuel line, into in-line marine filter, into primer bulb, into fuel pump, into carb.
I doubt this is standard. . .why is there a primer bulb in there? Correct me if I'm wrong, but there shouldn't be a need to squeeze a primer bulb on an engine that has a fuel pump?
I want to mount a spin-off fuel filter (eliminate the cheapo in-line) and go straight to the pump. My way is correct, right?
Modemagic
Re: Fuel plumbing on a Volvo AQ125A
I have a AQ145A and that is how mine is setup. (No bulb I mean) I do like the idea of the spin-off filter vs. a in-line filter.
JAL51974
I just bought the spin off fuel/water separating filter and plan to install it just as you said. I always thought that the primer bulb was illegal on an I/O? On the first start of the season I slip a primer bulb in the line just to assist the fuel flow to the pump after sitting all winter. Then I remove it.
Joe
ThePostMan
Illegal? Man, I just figured it was unnecessary!
I can't really see how it could be a safety hazard or anything, I just don't see any reason to pull the engine cover and squeeze a bulb, if I have a fuel pump that moves the juice.
tommays
Everything in the fuel system has to pass a CG burn through test Which MAKES OUTBOARD BULBS Illegal as well as inline auto filters
And outboard fuel filter with a clear plastic bowl is also Illegal
The fuel line before the pump has to be A-1 rated and after the fuel pump should be metal
Rubber A-1 can be used BUt it must be with approved hose fittings which are pretty hard to find
