NC waterboy
- Apr 6, 2006
- 38
I'll try not to make this to long but with enough info.I have a 97 Johnson 50 h.p. model J50ESLEUS. I last used boat in middle of Dec. I had intentions of adding fuel stabilizer but never did. The boat was running fine at that time but I finally ran it about 2 weeks into March and it had some issues. Before I cranked it in March I changed the plugs and gas but it was hesitating a little on the water hose. I took it out anyway and it ran o.k. at idle and half throttle but at w.o.t it was no stronger or possibly less than it would run at half throttle.I could push the key in to choke it while running and it would pick up for a second so I assumed it was not getting gas. I later took carbs apart and they looked good but I cleaned and put the rebuild kits in while I had it apart . I"m not sure where the jet is in these carbs so I may have waisted my time. I inspected the fuel lines and they appear solid, also put on new in-line filter. Checked fire at low r.p.m by pulling the wires while it was running and it shut off with each wire being pulled.The only other things I noticed is a little gas coming out around the gasket at the back of the electric choke when I pushed it and there seems to be an oil film coming out of the exhaust inside the prop. I hope this is something simple to you pros and I will be greatful for any suggestions that I could try. Plan to fix choke gasket and do a compression test this weekend just in case. Thanks in advance.
