Hello,
I have a '77 Johnson 35hp that is running well, but is leaking fuel from the powerhead, down the exhaust housing and into the water. It looks like the fuel is leaking near the bolts on both sides of the engine. It leaks while running at high speed and continues to drip when shut off.
Does this mean it's time for a new head gasket? Anyone ever replace one before? Is it OK to continue running the engine with this problem?
Thanks in advance for your help-Jeff.
