1982 mercruiser 120hp pre alpha leg
my problem is when i first got the boat (21ft morebas 7200) it had no water fuel seperator it only had a fuel bulb so i added a water fuel seperator after the fuel bulb but before the fuel pump thing is the bulb will not pump fuel anymore (it used to before adding seperator) and i have to put a drop of fuel in the carbs to start it and then its fine for the rest of the day any ideas would be very gratefully received... should i put the filter before the bulb closer to the tank???????
