Fuel mix mystery.. at least to me.
meyerboy
I have always just done what OMC tells me to, but I am getting older now, and I want to know why.
I have a JW12 (1956) that requires 16/1 fuel mix, a JW16 (1960) that requires a 24/1 mix, and two JW22's (1967) that calls for 50/1.
I THOUGHT that all of the 3hp motors above were the same powerhead.
Can the wisdom of the OMC advise team help me?
JB
Re: Fuel mix mystery.. at least to me.
During the span of time between the JW-12 and the JW-22 several things changed. Superior lubricants came along, OMC changed some specs and some materials.
I would stick with what OMC said back then and BRP is recently reinforcing.
Daviet
Usually the 16/24:1 engines had babbit type bearings and the 50:1 had needle bearings on the crank and rods.
Vic.S
And with no needle rollers in any of the three mentioned I dont think I would risk 50:1. 24:1 maybe but perhaps but no less oil than that.
Not only a question of lubrication but with no crankshaft oil seals they rely on the oil film in the bearing to seal the crankcase.
Daviet
Vic.S, doesn't the 1967 use needle bearings?
Daviet
I stand corrected. I keep forgetting about the small engines using babbit bearings longer than the larger ones. Sorry for any confusion.
