Zebramidge
- Jul 4, 2001
- 27
Planning to troubleshoot fuel system tomorrow morning on i/o boat. Limited mechanical experience. Need to vacuum check fuel line before vro pump for possible air in system and fuel restriction. Motor manual says to do it at full throttle for two minutes. Can I do this at full throttle in neutral without harming engine or should I be under load? This is probably a dumb question, but if the answer is I should be under load, how do I manage that and monitor gauge and vinyl tube at the same time I operate boat? Or do I need some kind of special test tank?
