Fuel Line Size Question 5/16 vs 3/8"
w2much
I have a 1988 110 HP. From the fuel tank to the motor is the supply hose or connecter an issue? Will the motor run the same with a 5/16" or 3/8" fuel line?<br /><br /><br /><br /><br />Thanks
WillyBWright
Re: Fuel Line Size Question 5/16 vs 3/8"
3/8 isn't required until you get to the V-6s.
w2much
Willy BWright and all others. Thank You. <br /><br /><br /><br /><br /> I also did a search and came up with the same conclusion.<br /><br /><br /><br /><br />Point being: Use the "Search" option before posting as is suggested. It contains a wealth of information.
dc in ms
greater than 6 feet in distance I would look a little closer at tube size.
w2much
Any body else? Facts and opinions welcome.<br /><br /><br /><br /><br /> Thank You
DHPMARINE
Original fuel hose and fittings (stock 6 gallon tank to motor) used 5/16 according to the parts manual.With a built in tank,we used to rig with 3/8 as that was the size fitting on the (then new) fuel tank.<br /><br />DHP
