sutor623
- May 23, 2011
- 4,089
Hey guys I have a '84 75hp evinrude. I changed all the fuel lines when I did a fuel system overhaul. 5/16" goes into and out of the fuel pump, then that goes into a T turning into 5/32" and goes to the three carbs. It is only a short run of 5/32". Anyways all I could find is 1/8" (4/32"). It will fit over the same connectors just a bit tighter. Do you think that this will cause a fuel delivery issue? If I did would engine run lean or simply just big down under heavy throttle? On here you can see the short run I am talking about. Part numbers 8,9 and 44. Evinrude Intake Manifold Parts for 1984 75hp E75TLCRD Outboard Motor
