when i pump the bulb, i get fuel going to the engine ok, and the engine starts great, but the bulb never gets hard--- is this necessarily the bulb, or should pressure stay tight at the engine side as well. The in-line fuel filter never actually fills, which suggests to me at tleast that there is no pressure build up on the egine side of the filter.
The reason why I am not quick to blame the bulob is that I have some fuel that accumulates in the engine housing that pools when the engine is tilted up after running. I don't see fule gushing out anywhere when i keep pumping the bulb-- i suspect it's getting into the engine head/cyclinders.
The VRO system was disconnected by a previous owner-- I wonder if there is a fule/pressure leak somewhere because of this. Could this also be part of the excessive smoking and occasional stalling while at idle/trolling speed (previous post)?
I am heading out to buy a new fuel line/bulb, but wanted to send this in case it rang a bell for anyone.
It's a 1989 150 'rude.
Thanks!!
Thanks!!
