I have a mercruiser I/O 130 hp with Alpha one out drive and I was warming up the engine and found that there ia a fuel leak on the fuel line into the carberator. I am not so well verse in engine and will try to descript it as best as I can. The line goes from the fuel pump into the carb (metal pipe) at the pint where it joint the carb there is like a screw connector into another piece that is bigger, then into the carb itself. It is at this junction that the fuel is leaking. I tried to unscrew the smaller on which fit a 16mm open wrench but the bigger one is like 22mm?? and it would not budge. I am afraid to put alot of pressure on it. IS the bigger piece screwed into the carb? And should I be able to get the small connector out can I use a teflon tape on it? I think this leak was ther since I bought the boat and have not notice it until now. Any help is really appreciated. Thanks
