Hi there<br /><br />I just installed a new fuel filter/water separater for my 1976 Merc 850 and to test it wasn't leaking I primed my fuel bulb as hard as it would go. I then noticed fuel dripping from the right side of the cowling. I pulled the cowling off and carb cover and found a heap of fuel pooled below the carbs which was draining out the side of the cowling. Should this be happening, do my carbs need rebuilding? It only happens when the engine is not running and I prime the bulb really hard. The fuel then slowly continues to run out of the bottom carb jet. Can anyone shed some light on wehter this is only happening because I'm priming the bulb too hard and the carb is overflowing or is something busted inside my carb causing it to leak. The engine also develops a loss of power after being switched off, once it is running around for a bit it will go fine but then problem will return when switch off and on again. Engine details are :Merc 850 Thunderbolt Blue Band Merc Eng No. 4366928. 4 coil electronic ignition NO DISTRIBUTOR<br />Thanks<br />Nial
