Alter Bootsmann
- Jun 11, 2011
- 34
Hi, I have a 1989 Johnson V4 110. I am new to outboards always had Mercruiser. My question is why when I trailer my motor, does fuel and oil mix come out of the engine? Is this normal? It drains into the drain well of the boat and out into the water or the road.
When I took the cover off,I could see fuel mix leaking around the "Air Silencer" area (at least thats what the parts manual calls the cover that goes over your carberator intakes).
Does the gasket on the "Air Silencer" normally keep this fuel from coming out? I am assuming this fuel mix is falling out of my carberators or the intake area? If so then maybe a new gasket might help?
I just had an impeller installed by the mechanic. Did he have to remove these parts to get to the shift shaft release? If so, that could be what started the leaking?
Any help is greatly appreciated!
AB
AB
