fuel issues 135 Evinrude
kcboat
compression 120 all cyl. good spark.will start but will not keep running.took carb. bowl off and blew out both carb.,all apeared to be clean.how ever i did not remove the jets. other than the float jet. when i pump the bulb it never get's hard it remains spongy.Is there any good way to verfiy the fuel pump is good. or if I have a carb. issue.
emdsapmgr
If you get the engine started, and find that you can keep it running if you constantly prime the fuel hose bulb-it's likely the fuel pump is bad/weak. The hose bulb should pump up hard the first time you go to start it each day. Once the engine starts to draw fuel thru the hose, the bulb will soften, but should not collapse on itself.
kcboat
gravity feed fuel fuel to elimate the fuel pump and bulb as i have just replaced fuel line and bulb.if i spray starting fluid down throat of the carb's it will start but not idle.
SparkieBoat
do not use starting fluid. use premixed gas instead, save your crankshaft. get a new blub and pump it up tight, if it does not get hard then you have a leaky needle valve or other leak which you should be able to see at some point of pumping the bulb. If the motor cranks and stays running because you continually pump the bulb then you have a bad pump. another way to test your fuel pump is to disconnect the hose going from the pump to the carbs, then turn your engine over, fuel should shoot out in fairly strong spurts.
kcboat
going to remove the carbs and try to clean them again.should i take the high speed and low speed jets out for cleaning and how do i readjust them when putting them back in?
