Hi Guys,
Just wondering if anyone could provide any insight into this issue. I have a 1984 johnson 9.9. It runs fine for about a minute or so then it starts to lose power. After a few minutes it won't run at full throttle and instead the engine will just starve and die. If i pull the choke out all the way it will run at full throttle but only at around 80% speed. After running it like this for approximately 20 minutes it almost entirely dies and at full throttle i'll only be going 2-3 km per hour.
The bulb is pumped and hard.
The carb has been cleaned. I could see the carb cleaner coming out of the jet. Even with the carb off I seen no varnished gas in the bowl. Carb looked like it was rebuilt not too long ago (fresh float)
The fuel pump is only a few years old (was replaced previous to this issue - well before the issue started)
The gas tank is vented.
It's fresh gas - no water in it.
Also ran some sea foam in the tank just for the heck of it.
When it starts to die i will pump the bulb but it's still firm and has no effect on the engine.
Could it be anything other than the fuel pump at this point?
Thanks,
Sean
Thanks,
Sean
