Fuel injector cleaner additive in 2 stroke ?????
magnoman
Is it poss to use fuel injector cleaner in 2 strokes outboard
micel
Re: Fuel injector cleaner additive in 2 stroke ?????
I run lucas injector lube-cleaner(one product)in all my injected engines,and have never had a problem with injectors pumps or any fuel problems in almost 10yrs.I even notice a increase of 10% increase in fuel economy in road vehicles. If engine is under warranty I made sure you ok it with them first.
magnoman
So this would work in a outboard 2 stroke?
eedwards
Sea Foam!
micel
I use it in anything injected including my suzuki dt150 2-stroke,but like I said okay it with your mechanic.I agree sea-foam is a great product for decarbing,I use the deep-creep version every 50 hrs.
rodbolt
if your not having a problem? it may work.
if you are having a problem it will burn a piston long before it cleans it.
have a nice day and support your local tech :)
