Re: Fuel Hoses
You should be using USCG approved fuel hoses on your boat. The reasons are for safety. Automotive hoses usually are not tested by the USCG. If it has been tested, it will state that it is, on the hose. When the USCG approves an item, it is put thru various tests all for safety reasons. Fuel systems are one of the areas you should not mess with, ALWAYS USE USCG APPROVED FUEL SYSTEM COMPONENTS IN YOUR BOAT.
