Re: Fuel gauge not reading correctly
Keep in mind that the fuel sender is a linear device. It reads Half when the float is half way down.
If your tank is set on the keel it is likely "V" shaped. Half way down leaves 1/4 full, not 1/2 full, but it reads 1/2 full.
Your tank may read full for a long time and then go from full to empty in short order. Not unusual!
If you are sitting bow up and the fuel sender is in the rear of the tank, the issue is even worse.
Boat fuel gages are notoriously inaccurate. Not because if the equipment, but because of the circumstances of their use.
Before you go disassembling or replacing anything.... With the boat on the trailer, crank the bow DOWN, If the gauge now read more like you think it should, there is not much you can do to correct the issue.
A full day on the lake means a lot of different things.
5 hours of constant cruising at 3000 rpm is a lot different from hanging out on a sand bar.
How big is the fuel tank and how much fuel does it take to fill it back up.
That is the real measure of how full you are!
