Cougar_15
- Aug 11, 2008
- 93
I'm at the lake for a week with my boat and I'm out of ideas as to what else to try to get my motor running right, I need some help...
The motor is an 1977 70hp Evinrude. It starts great, idles great, runs great at slow speed but bogs down on wide open throttle. With the fam in the boat it only gets about 3000 rpm, with just me it hits around 4000 rpm at about 3/4 throttle. Once the thottle is advanced past 3/4 it bogs down then surges. If I repeatitly bump the choke at wot it picks up rpms and stops surging. With just me I was able to get it to 5000 rpm.
I've tried everything I can find on the fourm to fix fuel flow issues and I'm out of ideas. Here what been done so far:
- Carb rebuilt using OEM kits (completely dismantled, jets removed, soaked, new seals and floats)
- Carb have been removed and gone through an additional 2 times to look for blockages and adjust the float levels.
- Compression checked: 120,115,120
- Spark checked: will jump 1/2 gap on all three
- Linkage adjusted per the OEM manual.
- Inductive timing light show consistent pattern on all three cylinders
- New spark plugs
- New fuel lines
- New gas
