i have put an extra fuel filter on after fuel pump but before carbs(aq130a) should this filter be full of fuel or just a trickle of fuel less than half an inch????
How does the boat run?
like pooh!!!! goes wot for a little while (20 secs) then coughs splutters and will only do about 5knts till it seems the float bowls on carb re-fill then goes wot again for 10 secs then splut splut splut so i put the filter on after the fuel pump and it dont seem like enough fuel is in there my only question is should the filter fill up with fuel?????
