theoldwizard1
- Feb 25, 2014
- 341
I have a 2001 Starfire 170LE. Basically an SS with a pedestal mount up front and in back on a casting platform. The fuel tank is either under the splash well or in the floor. The fuel feed to the outboard is through a fitting in the splash well. Not really much room in the splash well.
Where would you mount a fuel filter/water separator on this configuration ?
Related question. The vertical panel that runs between the rear casting platform and the deck is covered in marine carpeting. I assume it is screwed to some braces. Any slick ways of locating those screw heads buried in the carpeting so I can put this panel off and take a look underneath ?
