Fuel filter intake popping out - Mercury 9.9 outboard
Trauber
[FONT=&quot]Hi All,
Would really appreciate some help with this one. I have a 2002 Mercury 9.9 outboard and the fuel intake keeps popping out. It "clicks" in, but then almost immediately pops out when we start moving and the motor cuts out. I don't know that I'm naming the parts correctly, hope the picture is clear
[/FONT][FONT=&quot]. Is this a faulty part or should it be secured in some way? Thanks in advance![/FONT]
A lot of these connecters now look the same but are not.----------Make sure the clip is going into the groove to retain it.--------Visit a Mercury shop and get the correct one.
Trauber
Thanks for the quick reply, much appreciated. I should have given a bit more context. This clip was functioning properly for years beforehand, just seems to have started popping out now. Is it possible to replace and if so, what part should I order? Having trouble figuring it out.
Thanks,
Matt
ondarvr
Any marine supply store with have the connectors, so will Walmart and many other similar stores, you should be able to find one easily.
​Cut the old one off the end of the hose and take it with you.
