Fuel Filter Fittings
geo7
I am putting together a multi-stage filtration system for my cummins diesel. My question is what is the best fittings for this application. I will be using reducer bushings and a short pipe nipple. I heard that the sulfur in diesel fuel is not compatible with yellow brass. I am not sure if this is true.
Windykid
Re: Fuel Filter Fittings
I have never heard that. I have been using brass fitting on the low pressure side of deisel engine fuel systems for over 20 years.
Don S
I've never heard of that either, but if it concerns you, use steel.
geo7
Thanks for the quick replies. I will be using yellow brass. You wonder how these misconceptions about a issue start.
I Donno,......
I've been plumbing Diesel in Brass Fittings Longer than WK,+ I've Never heard of it Either.......
And,...........
The Sulphur is about Gone in the American Diesel Supply nowadays........
