HI,
I made the mistake of saying "I like fishing from the kayak better than my boat" in front of my boat. Since then, it's giving me all kinds of problems.
First I had a bad kill switch. While fixing that I must have disturbed the ingnition switch and had to replace it. I'm a total newbie at this, but am learning alot just from reading old posts.
New problem. I pump up the suction ball then push in prime on ignition switch. Engine will run great for 2 seconds then die. If I put the prime solenoid to the bypass position(lever forward)and squeeze bulb, I can keep engine running. I'm guessing that it's running because I'm forcing fuel directly into the carb throat(this is all from stuff I've read). Do I have this right so far?
The main fuel line goes into a T. On hose goes to the primer solenoid and the other goes to under the carb. What I don't know is what happens to the hose that goes under the carb. I'm guessing it's the main fuel line that goes to the bowl. I have no idea how the bowl, float, and needle valves work,,,so that's what I have to learn. It sound like mmy problem is in this area.
Any help would be greatly appreciated.
thanks,
Al
thanks,
Al
