magster65
- Sep 1, 2002
- 2,573
In general terms, what uses more fuel, a single big block or twin small blocks? (Say... 2 x 305/5.0 (200 h.p.) mercs. vs. 1 x 454/7.4 (330 h.p.) merc. in a 28' 10-12000 lb. planing hull). I know at low speeds the two small blocks would use more because of the larger engine displacement, but what about as you apply power? I'm thinking the twins would have an easier job (higher vacuum readings) and that may result in them getting the same or better fuel economy at cruise (2800-3000 +/-). How much would the cruise speed differ? My thought also is that the twins would easily outperform the big block but they are heavier than a single... any thoughts? Oh why not... how do you think twin 165 merc. 6 cylinders would stack up against either of those combinations?
