fuel diverter valve?
ziggy
well, i just keep haveing fun with my new (well used) toy. i've got 2 12 gal. fuel tank in my trisonic. i had a fuel diverter valve at the start of the weekend. however it wasn't diverting to the port tank. well anyways, the nipple broke off the starboard tank. left me hosed (pun intended) on the river, fortunetly on the ramp. so i put me on a t fitting for now. seem to be takeing fuel from both sides as for now, down to 1/3 tank. question, what if i only fill one tank, one full, one empty. will it take fuel from the full side, or the empty one. seems like i might be in for problems running with a t. ie suckin air from one side when ones empty and the other has fuel. also wondering about what is coast gaurd approved for a fuel diverter valve. the one that was there is best i can tell a TH marine water valve, with manual cable remote to dash. which is nice and i'd like to retain. but as of yet ain't found the exact replacement valve. not sure i want to as it's a water valve i think. opinions??? jim
Re: fuel diverter valve?
Well Ziggy,<br />Air Sucks Easier than gas.....<br />So, You're Right....... The "T" Won't work very well........<br />I've never seen a Cable operated 1.....<br />I Know that there are Manual,+ Electric Tank Selector Valves availible...........<br /><br />I've got a manual selector valve mounted on the transom......
todd5881
go get you a fuel diverter valve for a late seventies early eighties chevy truck with dual tanks, if i remember correctly they were cable controlled, if not an electric on should be easy enough to install! ask your parts house, how to wire an electric on! if they are any good at all they could tell you how to wire an electric on!! Good Luck
ziggy
thanks for the help folks. think i am going to get the issue solved. my marine dealer here has talked with th marine. guess the valve i had is no longer made. however he says that th marine is gonna retool up to make the one i need. wow. i hope that is whats gonna happen. all for only $30 for the new valve. thanks for the help. jim
