Hi folks, I'm working on a 2002 Mercury outboard motor on my Bass tracker boat. The boat had been previously neglected for about 4-5 years. The following work has been done to the motor: Carburetor has been removed, cleaned and new kit installed. Dumped all fuel from tank , mopped out dry and added new 93 octane gas with a can of sea foam .Sea foamed carburetor twice. Motor starts but dies out. Replaced all fuel lines and clamps Replaced fuel line and primer bulb assembly(Attwood). Same problem. Hooked up external tank with Quick Silver primer bulb and hoses and motor runs. Returned Attwood fuel line kit , purchased and installed new Mercury Quick Silver fuel line kit. Same old problem- motor runs but loses prime. I have also put a new fuel intake line into the tank(in which I cut it about a 1/4 " shorter than the old one to make sure it's not pulling on the bottom of the tank). We did take the boat out on the river and give it a good run. It runs pretty good under load but has the persistent low idle dying out problem. I would appreciate any help in this matter as I don't have much hair left to pull out.
