grizzlybars
Thread starter- Joined
- Jul 8, 2003
- 8
have a 65model 90 hp johnson. bought motor used. motor started up easily, but when i took it to the water it starves for fuel when giving it over half throttle. have replaced fuel pump diaghram, plugs, points and condenser, and replaced water pump impeller. bought 2 new plastic fuel tanks, with vents, new fuel line connecters on both ends, new hose, and changed primer bulb twice. tore down carbs and cleaned bowls and checked needle valves and seats- all in good shape. compression check showed 55lbs on all cylinders. was worried about this at first but have found out engine had lower compresion from factory and as long as they were all within 10% was good. engine doesnt miss or foul plugs and has no problems untill giving it over half throttle, has to be a fuel delivery problem or timing problem of some kind i hope. points are at .20 and timing belt is new and lined up. i dont have a manual to use timing light on this engine so any help would be appreciated. thnx
