rustyscrew
- Mar 29, 2006
- 141
This problem has some history so here are some pertinent details and chronology of problem:
Engine: E115FPXEEC
End of June, I got water in the fuel and it got past the water/fuel separator in the engine and stalled.
I drained some and took it into the shop and they cleaned the water from the system and replaced the plugs ($850).
I emptied the 40 gallon fuel tank, removed all water and replaced the sender and checked over the pickup.
When I attached the engine to the boat fuel tank after the service, there was a vacuum in the line and it was hard to get any fuel with the primer bulb
I removed the pickup and pulled the fuel directly from the tank to get the boat to its slip.
I figured the anti-siphon valve was rusted so I pulled it and cleaned it, but upon replacement it didn't fix the problem.
I bought a new anti-siphon valve and primer bulb and gave it to my co-owner to install.
He ran the boat but I don't think he was paying attention to the fuel line at all.
When I got on the boat next, the engine was running terribly. Wanting to stall at low RPM in gear and shuddering on acceleration.
The bulb would get sucked down at idle cruising the harbor. I could keep it running by pressing the bulb.
I went through every part of the fuel system, even trimmed the pickup so it is 1" from the bottom and replaced the antisiphon valve with a regular barb fitting. This solved the vacuum problem, but the engine still runs really badly and will stall at idle unless I pump fuel to it.
It strikes me as a low pressure fuel pump problem. Could this be induced by the bad anti-siphon valve?
The mysteries to me are:
1) why did the primer bulb only suck down at low RPM, but not at high RPM?
2) What are the chances of having 2 bad anti-siphon valves? Was there something else going on?
I apologize for a lengthy post but I tried to include the pertinent info. Basically the fuel system is fine now, but fuel delivery seems to be a problem. Is it a problem that was caused by water in the fuel or by running with a vacuum in the fuel line?
thanks in advance for any advice!
Engine: E115FPXEEC
