I've an 16 1/2' 87 Crestliner Viking (Nordic) with an 88 70HP Mercury on it. I'm wondering what is normal fuel consumption for this configuration. The trip is about 30-40 minutes each way running about 36-3800 rpms. The round trip will have used almost all fuel in the tank, on empty , but with a slosh factor left. The tank is one of the standard QuickSilver portables, 25 litres I believe.<br /><br />I'm not freaked by this, just puzzled. We used to run a 1990 18' Bayliner Capri Cuddy, with a 90HP Force. It would use a little more than 20 litres for the same trip in the same time.<br /><br />I thought that the Crestliner would do better as it is about 400lbs lighter.<br /><br />The mechanic said that the motor should be raised by two holes on the transom. Would this affect fuel consumption, or just the spray factor?<br /><br />David
