Fuel connector leak
redcat
Hi All,
I have a 1975 Johnson 15hp bought used. I used a brand new fuel connector to fire it up the first time and it seems to devielop a fuel leak at the connector when you prime it with the bulb. After it starts it does not leak. I inspected the motor side of the connector and it does not have a rubber on that part of the connector. Is it missing one? Any help is greatly appriciated.
Thanks Ron
F_R
Re: Fuel connector leak
Hi All,
No rubber on the motor side part. Does the commector seem to fit otherwise? There are look-alikes for other motors that do not fit (loose and sloppy). If it is the right one and leaks, take it back.
