batkins761
- Jul 16, 2001
- 27
I am recomissioning my boat with a ProV150. I hasn't been run for over a year. Is there something I can use to clean out the fuel system (a fuel additive, etc.)? I'd like to make sure all the gum, resedue, etc. is cleaned out as much as possible (without a full service tune up, which costs a arm and at least 2/3 leg here).<br /><br />Will the oil go bad too? Is there anything I need to do to the oil or injection system (other than to ensure it's working correctly, which I will do).<br /><br />I will change out the lower unit oil, replace plugs (see prev. post) and check water pump, etc. Anything else I should make sure to do?<br /><br />Thanks!<br /><br />------------------<br />Brian Atkins
